6
This discussion topic has been answered Discussion topic: Which booster for Sky max hub SR213
This message was authored by: vbnjki
I am confused with boosters (so many models, specs, mesh etc) and would appreciate some help..
I need to boost my signal from my Sky Ultrafast Plus (full fibre) with Sky Max Hub router (SR213).
I have looked at Sky Q Se210A on ebay but not sure if it is the right one
I have also looked at TP Link and bought the one below, but I think it is the wrong mesh
I am so confused and would much appreciate it if someone can anyone tell me which booster to buy?  Sky or TP-Link model?
Re: Which booster for Sky max hub SR213
@vbnjki wrote:
is there another way to get one of these pods?
No: they shouldn't be available from any other source, and won't work without the subscription supplement anyway.
Or a good alternative TP booster?
Wireless signal extenders from other manufacturers should function to some extent after manual setup but won't integrate with the Sky Max system itself.
@vbnjki
The Sky booster which matches the Max Hub is the 'pod'
These are only legitimately available on loan from Sky with the WiFi Max subscription supplement.
Avatar for vbnjki
My package is Sky Ultrafast Plus which guarantees speed to router but not wall to wall Wi-Fi.
i phoned sky and they say I would need to upgrade with a new 2 year contract and extra £5 a month.
is there another way to get one of these pods? Or a good alternative TP booster?
Avatar for vbnjki
I guess my only option is to speak to Sky as I am tied into my current deal for another 14months so need to sort it.
just looked at there broadband packages and the wall to wall guarantee is only 3Mb/s.  That's very slow.
@vbnjki
The speed guarantee when you have WiFi Max is higher,  it depends on your broadband package.
More info here: https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | sky Mobile | sky Soundbox | EE Apple TV 4K | EE Full Works FTTC
Or 10Mbs, or 25Mbs.  It's not actually a guarantee of speed though: it's a guarantee of a small refund if the stated minimum speed isn't achieved.
Perhaps worth noting that all WiFi is zero Mbs on the other side of a few walls.
