31 Mar 2024 09:24 PM
When using internet on PlayStation signal is intermittent. Lags a lot during playing
31 Mar 2024 11:46 PM
Hello you can try reset You broadband will work or no work
---but im keep want superuser---
01 Apr 2024 07:30 AM
Posted by a Superuser, not a Sky employee. Find out more@Andycook21 if you are connecting the PS using Wifi thst is likely to be the problem. Wifi is subject to interference which causes issues while gaming due to packet loss. Ideally use an ethernet cable, failing that powerline networking can work as that uses your homes mains wiring to carry the signal.. Alternatively try to improve the wifi signal using the hints here
