Discussion topic: When am I getting fibre optic –?
This message was authored by Psycal This message was authored by: Psycal
I live in the Wokingham area – many streets have fibre broadband – except ours – my broadband speed is so slow it's very frustrating to everybody that uses it – to the point I am under pressure to go elsewhere
This message was authored by daveNOS This message was authored by: daveNOS
Re: When am I getting fibre optic –?
@Psycal No one here can say when fibre will be available to you, you could look here https://www.openreach.com/broadband-network/fibre-availability to see if its planned on your street as it should give you a planned date if it is,
-------- Please note i am not a Sky employee ----------
@Psycal
The Openreach target to reach 80% UK FTTP coverage is the end of 2026.
Altnet deployment is on a totally different timescale and will vary between each ISP.
This message was authored by peter-marlow+1966 This message was authored by: peter-marlow+1966
Use the my sky app to check what broadband  speeds  are  available  to you
@Psycal
Note that the Sky sales system has a quirk where addresses currently supplied with Sky Ultrafast 1 over G.fast may be told FTTP isn't available when it actually is.
