5
This discussion topic has been answered Discussion topic: WhatsApp won’t connect to my Sky WiFi
This message was authored by: Criispy
WhatsApp doesn't connect in my home. When I switch WiFi off on my iPhone 12, it works. So the connection to my modem is the problem.
This message was authored by: Highlinder Answer
Re: WhatsApp won’t connect to my Sky WiFi
@Criispy  What is your broadband sheild setting set to? If you have not changed this it is set default to PG.
Avatar for Criispy
Thanks, you were correct. 👍
@Criispy  Did you change this so that you can use that app?
This message was authored by: Aldona
Don't understand
@Aldona
The suggestion is to change the age setting in Sky Broadband Shield to a less restrictive one because the default interferes with some social media apps.
