Discussion topic: Weak WiFi signal from router position in house
This message was authored by: Paddy132
Hi just wondering what the best way of boosting the WiFi signal in my house as certain areas seem to be dead zones and the signal drops. Router is not in ideal position in the house as it's in the far corner by the front door. Thanks in advance
Re: Weak WiFi signal from router position in house
@Paddy132
Either boosters from Sky if you have Sky Boost or Sky WiFi max, or if you dont have those then a 3rd party router/mesh system
I am NOT a Sky Employee
