Discussion topic: Weak WiFi signal around house
This message was authored by: James701
Message posted on 02 May 2025 09:35 PM
I need a extender to help build a stronger signal due to our thick walls
Message posted on 02 May 2025 10:20 PM
Re: Weak WiFi signal around house
@James701 do you have the Sky Max subscription package on your broadband account?
Find out more
If you have Wifi Max then you should be able to contact them to get a pod as per this:
