Discussion topic: We have the new sky max hub, we have had it sorted as it wasn't on-boarding, however we have 3 boost
This message was authored by: Celwill
We have the new sky max hub, we have had it sorted as it wasn't on-boarding, however we have 3 boosters (thick walls) and none of them connect, theres no reset button on these - so I do not know how to connect them to the hub. Ive been told they should connect automatically, but they dont, anyone have any ideas? Thanks
Re: We have the new sky max hub, we have had it sorted as it wasn't on-boarding, however we have 3 b
@Celwill what boosters do you have? The WiFi Max hub has mstched pod extenders but is not compstable with other Sky boosters. If you have the 3 pods move them to be close to the hub and plug them in one at a time. Once linked you can move them back to their normal positions.
Help video here https://www.youtube.com/watch?v=BUB9ArVrTko
Edit to change to correct help,video
Avatar for Celwill
thank you so much Ill try it now !
Avatar for Celwill
Unfortunately this hasnt worked!
@Celwill call Sky.
@Celwill
To be in possession of three Max pods you should have received a visit from a Sky WiFi specialist: did that not happen?
Avatar for Celwill
I did have an engineer however I have now called sky and another engineer is coming out to sort ! 😊
