24 Feb 2024 05:23 PM
We are still having trouble with our booster box it keeps dropping out and has been like this for 4 days why is this could it be a fault in the box
this is causing all sorts of issues with our other equipment ie printer and then I had Trouble with my fit bit watch lost all data and clock and had a lot of trouble getting it back getting really fed up with this will seriously think of leaving when my contract ends
24 Feb 2024 07:07 PM - last edited: 24 Feb 2024 07:48 PM
@June_russell Which booster and hub do you have, if booster is moved closer to the hub does it improve.
If sky booster then led's on the unit can flash if weak signal. But it is possible unit could be faulty...
Sky.com there is help to explain issues.
25 Feb 2024 08:33 PM
Hi guys yes I tried moving the booster near my hub and it makes no difference anyway in the end my husband reset the main box so then we had to get everything up and running but good news the booster is now ok but still can't get our printer working it just won't connect to internet
