Discussion topic: Wanting to change wifi max router 5ghz channel
This message was authored by: Db98
Hi ao my router 5ghz keeps auto selecting channel 157 which causes my extenders to not connect to the router can't change wifi setting via Web browser and setting don't show on the my sky app
Re: Wanting to change wifi max router 5ghz channel
@Db98 there is no way to msnually control the channel the Sky Max hub uses, it is 100% automatic. This is because like many other modern routers the hub can use partially restricted frequencies which can only be used if there is no higher priority user like a radsr station within range.
Use of non matched extenders is therefore difficult and it is not recommended. The recommended solution if you do not want to use Sky's WiFi Max pods is to turn off the hub's wifi and connect a third party wifi access point by Ethernet. This is how my own set up is connected.
@Db98 What make and model off extenders are you currently using with the sky Max hub?
