Discussion topic: Wang to speak to an advisor
This message was authored by: Richard169
Want to speak to an advisor
This message was authored by: daveNOS
Re: Wang to speak to an advisor
@Richard169 If you want to speak to an advisor you will have to call, the forum is manned mainly by fellow customers.
@Richard169
Perhaps if you tell us what the Broadband issue is someone on here can advise you and save you a call.
If you definitely need to call Sky you can call free by dialling 150 from your Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you here to the forum. Stay on the line as long as possible and don’t hang up.
