Discussion topic: WIN10 Desktop PC won't detect SKY broadband wifi network
This message was authored by SKYUSER36 This message was authored by: SKYUSER36
Switched from BT to Sky Max hub broadband. Every device in the house is connected and working fine, yet my Windows 10 PC does not even see the network, though it does see the SKY network belonging to the neighbours. Have tried every possible solution available including forcing only 2.4ghz band via router . Drivers are all updated and the PC would connect to mobile hotspot etc, this seems to be a very old issue (and resolved) with sky broadband based on information available on the web but none of it helped, any suggestions?
WIN10 home
Version 22H2
Re: WIN10 Desktop PC won't detect SKY broadband wifi network
@SKYUSER36 do you have the newxwhite Sky Max hub one lateral thought as if you have is maybe your PC cannot cope with the new WPA3-T WiFi security standard that uses by default. If you suspect the using the My Sky app you can switch the hub to use the older WPA2. As I say its just an idea.
SKYUSER36
Thanks for the reply and Yes I have changed it WPA2 as some other devices were not able to connect
