Discussion topic: WIFI SAYS ITS WORKING BUT CERTAIN SITES NOT WORKING
This message was authored by: Lilly90
Hi, I'm having a real headache with my connectivity. My wifi seems to be working, my router is all lit up green, I've done all the troubleshooting suggestions, but I'm finding that certain websites aren't working and will only work if I switch to mobile data. This is happening both on my phone and on my laptop. It seems like larger bandwidth sites aren't working properly - I can't load whatsapp, I can't see pictures, I can't open Pinterest, I can't receive Whatsapp calls - although sometimes it does work. So it's unclear what the actual problem is - everything looks to be connected and online but certain sites and apps aren't functioning properly.
Re: WIFI SAYS ITS WORKING BUT CERTAIN SITES NOT WORKING
@Lilly90
Try adjusting your broadband shield settings. You can do this via the MySky app or online here:
https://www.sky.com/myaccount/bb-and-talk/broadband-shield
Avatar for Lilly90
Thank you so much! Seems like I had a shield on social media which would explain only certain websites not working!
Hopefully this has resolved it 🙂
@Lilly90 May take a few hours to filter through but good chance it will all start working as you expect it!
