Discussion topic: WIFI Booster has disconnected from Wifi hub and won't reconnect.
This message was authored by: Jonathan953
My booster has disconnected from the hub and won't reconnect. Tried to re-connect, but no good. Tried also being closer to the hub. Also no good. Power and WIFI green lights are on but connected light is not.
Re: WIFI Booster has disconnected from Wifi hub and won't reconnect.
@Jonathan953 what model hub and booster do you have?
Avatar for Jonathan953
Hub is SR203 and  Booster is SE210. Worked fine for the last year.
This message was authored by: Metis
Hi @Jonathan953
Have tried pressing the WPS button the booster, then pressing the WPS button on the SR203?
