Discussion topic: Very poor WiFi speeds below 5 for download making TV impossible to watch
Message posted on 24 Aug 2024 07:45 PM
Rubbish download speed below 5
tv impossibly to stream
signal bouncing in and out over the last 3 days
Message posted on 25 Aug 2024 07:34 AM
Re: Very poor WiFi speeds below 5 for download making TV impossible to watch
@Elaine73525 run the full connection test innthe My Sky app as if thecspeed to your hub is below the guaranteed speed for your line it should i]offer to book an engineer to check your line. It will also show the history for the last few weeks.
If tgst looks fine tge issue is WiFi speeds in youur home which Sky cannot control you can do a limited amount yourself such as making sure the Sky hub and the device you are using to stream are out in the open not under or behind other kit. Beyond thst assuming the issue isnt other people in your home using bandwidth while you arexwanting to watch TV you need to considefeither buying one of Sky's add-ons like WiFi Max or buying your own wifi kit.
