21 Sep 2022 02:47 PM
I switched ISP a couple of days ago and I cannot connect to my works VPN using Sky broadband. I've already followed a lot of works diagnostic steps with no luck. Is there likely to be anything Sky is doing to prevent the VPN working? I have disabled broadband shield, and I have the new sky hub as a router. Have tried changing a few settings on router and nothing works.
22 Sep 2022 11:21 AM
Thanks. I managed to find the issue - I had a virtual switch configured in HyperV. I removed this and it now works.
21 Sep 2022 03:16 PM
Posted by a Superuser, not a Sky employee. Find out more@jondm there is nothing specific stopping VPNs unless your company has decided to use the same IP address range as Sky's default which is 192.168.0.1 as the gateway address. If they have (and they should know better) you will need to change the defaults on your hub - log into 192.168.0.1 and navigate to the LAN IP setup tab and change the settings to 192.168.1.1.
If dtill stuck post the name of the software yiu are using to connect.
17 Oct 2022 05:37 PM
It doesn't let me change my IP address to the one your saying, every time I try to change it and press apply it says it lost connection to server ? Will I get any luck ringing them?
02 Jun 2023 07:00 AM
Hi, I'm having the same issue (only since switched to sky). Could you possibly talk me through how to check for and remove this virtual switch?
02 Jun 2023 07:36 AM
Posted by a Superuser, not a Sky employee. Find out more@penyjen if you are having issues with a work VPN since switching to Sky first thing is to talk to your company's IT support. The OP found their issue was due to something unrelated to the change in ISP which was in the dnd co-incidental.
02 Jun 2023 08:38 AM
Hi, thank you for replying. I've already spoken to company IT support, had a sky engineer round, spoken to the software support.
13 Feb 2024 03:27 PM
how did you do this step pls?
13 Feb 2024 04:10 PM
Which step?
