Discussion topic: Upgraded wifi is worse
This message was authored by: Lisestedders
I have just upgraded to fibre. Since doing this the wifi on my phone is terrible. So much so, I missed my grocery delivery as they were ringing the ring doorbell which wasn't working on my phone. Paying £8 more a month and it is worse. What can I do?
Re: Upgraded wifi is worse
@Lisestedders Are you stiil using the same sky Hub that you had before the Fibre Upgrade that you did? FF500 and it's as solid as a rock, has been for the 14months so far and has NOT missed a single beat!
There is something that has happened if your phone has got so bad so quick from a straight Fibre Upgrade, hope the sky Hub did not move too far from were it was previously also!
