Discussion topic: Upgrade to full fibre
This message was authored by: Biggles491
Message posted on 21 Nov 2024 04:23 PM
Can I retain the same SSID and Password if I upgrade to full fibre
Find out more
Message posted on 21 Nov 2024 04:27 PM
Re: Upgrade to full fibre
Which model of Sky Hub do you currently have?
Find out more
Message posted on 21 Nov 2024 04:30 PM
@Biggles491 it is relatively easy to change the default SSID and password the hub comes with to match your old router assuming Sky send you a new one. My own system is using a password from a hub about 3 back.
See https://www.sky.com/help/articles/find-and-change-your-wireless-password
