1
Discussion topic: Upgrade to Fibre to Premises
This message was authored by thisMarco.dev This message was authored by: thisMarco.dev
Hi,
After few compains I managed to get OpenReach to come and install FTTP at my house.
I have already I Sky Broadband Superfast.
Once the installation is completed, do I need to phone Sky or I can just connect the router to the new Optical Network Terminator?
Thank you.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty Answer
Re: Upgrade to Fibre to Premises
@thisMarco.dev
You'll need to contact Sky, your current provision will be over copper (as you have Sky Superfast already and the fibre is a new install) and Sky will need to arrange an upgrade to fibre.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
@thisMarco.dev
