Discussion topic: Unable to reserve LAN IP addresses
This message was authored by: Jereon+Keppens
I recently upgraded from Sky Superfast to Ultrafast broadband and received a new Sky hub.  Currently, I am trying to move my settings from my old hub to the new hub.  I have tried to back settings on the old hub and restore them on the new one, but that failed.  That leaves manually changing all the settings.
Either I am missing something or the software on the new hub is very buggy.  I have followed the help instructions to the letter: Navigate to Advanced -> LAN IP Setup, Click Add under Address reservation, Select the IP address I would like to reserve, Click add.  This does not add the address to the table of reserved addresses.  I have tried the above with rebooting and without rebooting.
Re: Unable to reserve LAN IP addresses
@Jereon+Keppens
Which Hub model are you using?
Typically Hub administration using the Safari browser from a wireless device is very glitchy.
The Max Hub is administered through the My Sky app rather than a web interface.
Avatar for Jereon+Keppens
Doh!   I should have tried different browsers.  I have an SR203 and all works well on Chrome.  Thanks for pointing that out.
