15
This discussion topic has been answered Discussion topic: Unable to reach a website because of ERR_CONNECTION_TIMED_OUT
This message was authored by: Kelbrooker
My first ever post, so please be patient.
I receive the error ERR_CONNECTION_TIMED_OUT when I attempt to access pendle.gov.uk   .
I have already taken the following actions to no avail as recommended by Sky Support at various times:
Cleared caches (Internet,DNS,etc)
Changed browsers (Chrome,Edge,Safari)
Changed devices but using the same wifi (PC-hardwired, Ipad over Wifi, Phone over Wifi)
Always had the Shield disabled but enabled it and entered the site to permit access - nothing changed and reverted to Shield disabled.
Tried incognito mode on Chrome and Edge
Reset the hub
Turned the hub off overnight - 10 hours
Closed down my antivirus to ensure no conflicts (Malwarebytes) - I also uninstalled it and installed AVG - same result
Other things as recommended, but can't remember!
IF I USE 4G FROM MY PHONE IT WORKS!
I am just hoping someone can help!
Avatar for Kelbrooker
This message was authored by: Kelbrooker Answer
Re: Unable to reach a website because of ERR_CONNECTION_TIMED_OUT
@Kelbrooker
Could be a public IP issue. Unplug your hub for 1hr to get a new one.
Or if you'd rather not have the downtime you can login to the hubs admin interface and then 'Disconnect' then 'Connect' the WAN.
I am NOT a Sky Employee
Thanks but already turned off the hub for 10 hours.
@Kelbrooker
What about manually changing the DNS to something other than Sky's?
@jamesn123  Your last suggestion went way over my head and my competance 🙂
@Kelbrooker
In Windows 11 go to Network & Internet settings > Ethernet > DNS Server Assignment > Edit
Change it to manual, toggle IPv4 to ON then set the preferred DNS to 8.8.8.8
@jamesn123  I thought I should add that i would be happy to do as you suggest, if I knew what to do.
Also, if this is a sky probglem, shouldn't they fix it?
@jamesn123  thank you, I will try 🙂
@jamesn123 Here's the latest! I read up on the DNS server assignment for Windows 10 and also DNS server addresses. (Just for info, I used to be in the IT Industry from the very start but never comms, so at 75, I rely on everyone else, if possible) I didn't try 8.8.8.8 which I believe is Google as It wanted a hex? values for IPv6 and I couldn't find them easily. I did get the info for Cloudfare and I changed everything for IPv4 and IPv6 both DNS servers and alternates. Restarted my PC and loaded Chrome. So much quicker with Cloudfare BUT it still will not resolve pendle.gov.uk  . Any more of your excellent thoughts would be greatly appreciated.
@Kelbrooker
The following would be my only suggestions which I think you've tried already
- Try different device
- Try device connected in a different way to the hub (Cable vs WiFi)
- Change device DNS
- Use incognito mode
- Turn off Sky Shield
- Get a new public IP for the router
The only thing I can suggest is trying the public IP solution again. This time make a note of your current public IP then switch your hub off and when you switch it back on check its public is different from what you made a note of before.
@jamesn123
I will try the public route from scratch again and if that fails I guess I will go back to sky support and get a new hub in the hope that a different spec might work differently. Who knows? But before I go, thank you for your invaluable help. Greatly appreciated!
@jamesn123
Hello again! I thought that I would provide an update on my original problem.
New hub arrived today. Theorhetically the same device, spec, etc. Just installed it and the problem has disappeared! Magic or dark art, I don't know which.
Thanks again for your help.
One final question, if I may. I have a Sky booster/access point, call it what you will. Do I need to do anything to it, now that I have changed the router/hub?
Hub sorted.
This message was authored by: SteveWF
Did it permanently fix it for you?  I just received a new router and still have the problem
Hi SteveWF,
The new router did fix my problem. For some reason it did not like one particular URL. In all my 57 years in the IT industry (yes, I still do the odd job) I had never come across a problem like this, but elimination testing said it had to be the router and it was.  If you have a booster, as I do, it was necessary to take both new router and booster back to factory settings and then sync them both again. Then everything worked. Hope that helps.
