2
This discussion topic has been answered Discussion topic: Unable to pair with 2.4ghz smart sockets
This message was authored by: Ikr66
Upgraded to hub 4.2 and now unable to pair, was ok before with older hub
Re: Unable to pair with 2.4ghz smart sockets
@Ikr66
As posted by @jamesn123
Note that this process does not apply to the new (white) Max Hub
So to split the two channels you need to go to your router config page which can be found by typing 192.168.0.1 into your web browser.
To access the page, you'll need;
username: admin
password: sky OR your WiFi password
- Select wireless from the navigation bar and scroll down a little and untick the 'Synchronise 2.4GHz and 5GHz settings'
- Scroll to the bottom of the page and hit apply.
- Once the page reloads you need to go to the 5GHz wireless settings page on the sub navigation bar below where you click wireless before
- In the 5GHz section you want to go to the box called 'Name (SSID)' and add something like 5g to the end of the current name
- Scroll down and hit apply
- Then on any wireless device you should now see two networks. One network will be the same name as usual and will be 2.4GHz band and the other will be the usual name with 5G on the end (Or whatever you typed). Connect any 5GHz capable device to the 5GHz network and see if it works correctly. The WiFi password should be the same if you havent changed it.
@Ikr66
username: admin
Avatar for Ikr66
Thanks!
I have now been able to pair my smart sockets.
Now do I keep the same config with the *5g for 5ghz and the synch unchecked? Or do I revert the settings back to how they were before?
