5
This discussion topic has been answered Discussion topic: Unable to connect to new Sky Hub
This message was authored by: SJ071
When I try to add the password for the new hub I receive a message ... unable to connect to SKYNIBIU....     There are 3 green lights lit on the front if the new hub.
Re: Unable to connect to new Sky Hub
Are you entering the password correctly as it is on the card that came it and not entering a letter 0 instead if a zero 0 ?
Avatar for SJ071
Thank you for your reply. There are no zeros or letter O's in the password.
Avatar for SJ071
Also the error message is saying Unable to connect to Hub ........ etc. It is not saying incorrect password.
Avatar for SJ071
I was typing the password incorrectly. I mistook the letter f for number 1. I only found the error when I checked the password on the hub with a magnifying glass. I am sure Sky could give more user friendly  passwords on their hubs. Thank you for the tip about checking the password.
Unfortunately 'user friendly' can mean a drop in security if it reduces the complexity of the WiFi key.
