4
This discussion topic has been answered Discussion topic: Unable to connect Tapo to new sky max router
This message was authored by: A+WP
I've recently had sky fullfibre installed and have the better router sky max. Unfortunatly since installation I'm unable to access my 2 outdoor wi-fi cameras. Setting up the cameras they say that the cameras wi-fi addess isn't connected to the internet. Any help would be appreciated
This message was authored by: jamesn123 Answer
Re: Unable to connect Tapo to new sky max router
@A+WP
The My Sky app, your router settings are in there under products
I am NOT a Sky Employee
@A+WP
You may need to temporarily disable 5ghz WiFi to connect the cameras and/or change your security mode to WPA2 rather than WPA3.
Both of these can be done within the advanced settings area on the app.
Avatar for A+WP
Thanks for the answer james thought that be the issue but not being very techy and an ageing pensioner how do I go about resolving and what app do I need
@A+WP
Avatar for A+WP
James yur a starwent into mysky app and made changes to allow cameras to be connected Great thanks
