Discussion topic: Unable to check whether WiFi router is broadcasting dual band
This message was authored by: LRbb
Have been able to get to my router summary status, but can't log in as admin (with Sky password) to any of the tabs, such as WiFi tab.
When I try logging in I get another secondary similar login pop up.
Anyone ever dealt with this problem?
I have a couple of devices that don't play well with 5Ghz.
thanks,
Liam.
Re: Unable to check whether WiFi router is broadcasting dual band
@LRbb
Which hub do you have, black or white.
What browser are you using
Avatar for LRbb
Black Sky Q job with Chrome on mobile.
@LRbb
For the sky q the username is admin  and password is sky
The steps are below
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Avatar for LRbb
Thanks, Cookiemonster. Mine was the upright black box and neither the user suggestion or admin plus sky pass allowed me to enter the WiFi tab. I checked what my work laptop was connecting to and it did appear to be successfully using 2.4ghz. Pulled remaining hair out and did a factory reset on the router. This changed the ssid back to a singular name to which both non-connected devices now are able to recognise and connect. Cheers!
