Discussion topic: Unable to access anything on Sky Hub, get 401 Not Authorised message, unable to reset to factory.
This message was authored by: Rambo55
Unable to access anything on Sky Hub, get 401 Not Authorised message, unable to reset to factory settings.
I can see the summary status page but get 401 message when trying to access anything else.
I am trying to access as Wifi internet keeps dropping even though there is a connection to the devices, cable access is ok and I am using both 2.4 and 5GB.
Re: Unable to access anything on Sky Hub, get 401 Not Authorised message, unable to reset to factory
If you are not using anything like a VPN have you tried a reboot of the hub at the mains ?
Avatar for Rambo55
I have, many times. I cannot even access the maintenance tab (same 401 Error) to update security policies etc.
