05 Feb 2025 10:20 AM
I am unable to SSH into remote servers when using Sky WiFi. However, I can connect successfully via any other WiFi network or my mobile hotspot. I am using a Mac M1.
Additionally, I am unable to connect to my VPN through a VPN application specifically on Sky WiFi, whereas it works fine on every other network on the same laptop.
I have already enabled DMZ and disabled the Broadband Shield in the MySky app settings.
Could you please help me troubleshoot this i
ssue?
05 Feb 2025 10:21 AM
Are you using a white Max Hub?
05 Feb 2025 10:34 AM
Yes, white one
05 Feb 2025 10:36 AM
There's a fundamental difference in how Sky delivers network service to a Max Hub.
I'd suggest you refer to the pinned post at the top of the Broadband forum.
05 Feb 2025 11:09 AM
Thanks, the forum link in the pinned post isn't opening anymore. Apparently, it's used to request a change in service. Any idea if there is an alternative way to fix this instead of contacting the vpn provider's customer care? Because I'm not sure my VPN would even accept my request just for me, because it is working for everyone else using other broadbands.
05 Feb 2025 11:32 AM - last edited: 05 Feb 2025 12:31 PM
I'll try escalating your post. Effectively you are asking for a change in the Sky service because it's almost certainly their default deployment of Map-T which causes the issue.
05 Feb 2025 11:39 AM
Posted by a Sky employeeThanks for escalating this. We’ve sent Lal123 an invite to chat.
10 Feb 2025 10:47 PM
Hi @Lisa-P1987
I have had the exact same problem since switching to SKY. The SSH doesn't work anymore, and nothing has changed except the router/isp.
Can you please help?
Thanks 🙂
11 Feb 2025 07:29 AM
Posted by a Superuser, not a Sky employee. Find out more@Norton33 see the post pinned at the top of the forum and folow the instructions there.
11 Feb 2025 10:14 AM
Hi, thanks for this, but as previously mentioned by other users the link is not working.
11 Feb 2025 12:01 PM
Posted by a Sky employeeHi @Norton33
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
