Discussion topic: Tv won’t connect to internet whatsoever it’s done reset, restart both
This message was authored by: Elena13
I have tried everything what could be done to connect my Samsung tv to Sky WiFi
the other devices in my house working perfectly fine with the internet besides the Samsung tv
is there any chance to know what I can do
before it was working just fine since I move to sky internet it's stopped working
Re: Tv won’t connect to internet whatsoever it’s done reset, restart both
@Elena13 if you have a white Sky hub go into the settings for the hub in the My Sky app go into the Advanced `settings choose WiFi security and change tge level from WPA3T to WPA2 which should allow your TV to connect.
Avatar for Elena13
Thank you so much, that worked
will I be charged for this ?
if I have done this  change?
also I forgot to mention I have talk to someone form Sky and just advise to get in contact with the TV provider 🙄 but I couldn't the tv was fine just using another internet service
