Discussion topic: Tv buffering constantly since change to full fibre
This message was authored by: Angela28
I upgraded recently to full fibre broadband and the service has been the worst since I joined sky probably 15 years ago. My Samsung TV just constantly buffers. Help,
Re: Tv buffering constantly since change to full fibre
@Angela28 a TV buffering  is usally caused by poorcWiFi signal level. Check you have your hub in the best place which is on a surface well away from other electrical gear above obstructions like radiators. You may need to buy a loner Ethernet cable to link your hub to the ONT unit the engineer fitted. You dont need anything special. Ethernet cables are easily bought in varios lengths on-line, at hardware shops or most larger supermarkets.
If that doesnt help consider upgrading to Sky's WiFi. Max bundlecwhich can provide extender pods to improvecthe WiFi signal.
