Discussion topic: Tv apps won’t update via sky broadband
This message was authored by: Pablo1
I can't update my LG tv apps via my newly installed sky broadband. But I can update the tv apps if I connect the tv to phones hotspot WiFi.  Clearly the problem is with the sky broadband. Any ideas anyone please?
Re: Tv apps won’t update via sky broadband
@Pablo1  If you are new to Sky have you tried to change the broadband shield settings on the Sky app and go to the broadband and talk tab and scroll down you will see the broadband shield. The default setting is PG13 you might want to change this to say 18 + and save the changes to see if this will let you update the apps.
Avatar for Pablo1
Thank you for taking time to answer.  I have just tried your suggestion however it's not resolved my issue.  But I really appreciate your help.
@Pablo1  Do you have a white router from Sky?
Avatar for Pablo1
The router is black. Thank you
@Pablo1Can you follow the directions for to split the Wi-Fi bands on the rotuer to see if the apps will update on the 2.4GHz frequency please.
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
This message was authored by: RCorn
Hi I have a newly purchased LG tv with exactly the same issue as being discussed in this thread. And LG seems to know nothing about the issue, nor does Currys who sold me the tv in the first place and have now tried (twice) to get it to work. Can anyone tell me whether this option of splitting the Wifi bands (I have a black Hub) works? If not, how do I get to talk to someone at Sky to wave their magic wand over the problem?
@RCorn  You can try the spliting of the Wi-Fi bands. The process can be reversed if it does not work.
Split hub SSIDs as suggested and tried connecting LG tv to both 2.4 and 5 GHz versions. Connected successfully each time but LG apps still would not update. Same error message each time - e.g. "Failed to update Netflix. Try again. 24.20.SM". Any other suggestions (beyond getting a Samsung)?
This message was authored by: SpaceSparkie
Posted by a Sky employee
Hi @Pablo1
I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Sarah
Community Moderator
Sarah
Community Moderator
Hi @RCorn
Sarah
Community Moderator
Sarah
Community Moderator
This message was authored by: Tom-W19
Thanks for escalating. We've sent an invite to @Pablo1 and @RCorn.
Tom
Hi @SpaceSparkie. Thanks. I left the tv on all last night. Message on it this morning that its software had been updated, but same issue when I then tried to update its apps.
Avatar for Pablo1
Hello everyone
well yesterday whilst talking to Tom about my problems with the LG tv not being able to update the tv apps via sky broadband, I was trying to see the error messages and all of a sudden the tv apps started to update.  They are currently working fine with the sky broadband WiFi.
I personally didn't change anything on the broadband, and as the tv software is still the same version as when I had the problem. I can't explain or understand why it now works.  But the good news is it does work.  Thank you to everyone for helping and taking the time.
Hi @Pablo1  - same for me. Issue still there around 3pm yesterday and not there around 5pm. I did nothing and as far as I know @Tom-W19 did nothing. Some weird time switch in WebOS (all connection issues have to wait 2 days in a queue)? Fingers crossed that things continue to work from now on in and that app updates are no longer an issue. And many thanks to @Tom-W19 , @SpaceSparkie and everybody else who helped!
