09 Aug 2022 10:24 AM
You are fibre to the cabinet as fibre to the exchange then copper to the house has a maximum speed of 24Mbps
Just don't switch the hub of for 10-14 days whist your line retrains
Also enter your full postal address below and post the table after removing your address from the image. I am intrigued about the 200Mbps option
09 Aug 2022 10:34 AM
Hi
Yes, that's what he said, 200mbs.
If copper wire to the house can only be 24mbs, why is there a minimum guarenteed of 50mbs??
I'll look at the link now.
09 Aug 2022 10:36 AM
You are not on sky essentials adsl you are on superfast fibre to the cabinet which has a maximum speed of 80Mbps
Could you post a new set of hub stats
09 Aug 2022 10:37 AM - last edited: 09 Aug 2022 10:58 AM
@Manuka wrote:
He did say that we are only fibre to the exchange but he showed me there is fibre in the road now so we could get speeds of around 200mbs if we had fibre to the house.
No: you're on FTTC (Fibre To The Cabinet). 'fibre to the house' (FTTH / FTTP) can carry up to gigabit (900/100Mbs).
09 Aug 2022 10:38 AM
Sorry yes, to cabinet
09 Aug 2022 10:42 AM
It's not letting me in to the hub admin. Tries "admin" and "sky" and tried hub password?
@cookiemonsteruk Finally got into hub, here's the statistics
09 Aug 2022 11:04 AM
You are getting 60Mbps with a wee bit of room for improvement. How are you testing when you run a speed test? wifi or ethernet and make sure that nothing else is downloading in the background
09 Aug 2022 11:10 AM
Over wifi. Nothing downloading although my partner is working from home on internet.
09 Aug 2022 11:12 AM
@cookiemonsteruk Here's the result from the BT line check. I only really understand the first two rows.
09 Aug 2022 11:36 AM
According to openreach max speed is 60Mbps with a guarantee of 30-35Mbps. So assuming you entered the correct address info the line seems to have been downgraded. Also there is no option for any faster speeds certainly not 200Mbps
09 Aug 2022 11:39 AM
@Manuka you would need to run a speed over an ethernet device using fast.com or similar with absolutely nothing running .
09 Aug 2022 11:47 AM
Ok, I'll dig out an ethernet cable and try that
09 Aug 2022 11:49 AM
Thanks.
If that's the case, why do Sky guarantee a minimu of 50Mbs?
09 Aug 2022 11:54 AM - last edited: 09 Aug 2022 12:30 PM
ISPs typicall base their 'guaranteed minimum' on the 'handback' figures provided by Openreach/BT Wholesale with a bit of a margin. These aren't necessarily accurate in practice, in which case the ISP typically reduces the minimum figure and offers the customer a chance to leave without penalty.
