Discussion topic: There’s an issue with my broadband it’s not connecting
This message was authored by: Conn95
I have an issue with my broadband it's not connecting.
This message was authored by: JP0915
Re: There’s an issue with my broadband it’s not connecting
Mine has gone too.
This message was authored by: Hanny
Same here, 1st and third light are static green, nothing on 2nd light and 3rd light is static orange. This is the black sky hub on ultrafast fibre.
This message was authored by: TS12
And mine but service check on sky site says all ok!
This message was authored by: MarkG0806
And me - says ok but is not
Avatar for Conn95
That's like mine it's annoying tbf
This message was authored by: Zoe198911
Having the exact same issue to! First and third light green, middle light flashing Amber or nothing at all. Service checker tells me everything is fine! Might be some issue somewhere by the looks of it
Avatar for Conn95
Honestly don't know what's going on with it! I've reset my router and everything!
This message was authored by: Azariamallin
Mine is doing the same, Ive checked my status on the app and it says it's good, Ive reset my hub etc and still not working. Can anyone offer a solution or is Sky completely down?
This message was authored by: Crystal111
1st and 3rd light static green, middle light static orange but checks say everything is OK???
Mine has just come back on, might be best to turn off router for 30 seconds thenturn back on and see if it then connects?
Seems to have sorted itself after unplugging the socket.
Mine just back on. In West Midlands
Sky supplies something like six million domestic addresses with broadband across the UK, so no, probably not.
An ISP outage in a particular area is always possible, though, as is a failure for all ISPs caused by local Openreach infrastructure damage.
