Discussion topic: The middle light on box turns orange
Message posted on 20 Jul 2025 12:56 PM
It's like my internet is switching off 5/6 times a day
Message posted on 20 Jul 2025 01:01 PM
Re: The middle light on box turns orange
I have moved your post from the Sky+ board as your post seems to suggest a broadband issue.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
