Discussion topic: The lights are on but no connectivity
Message posted on 13 Sep 2025 01:47 PM
The WiFi cut out late last night.
The router is displaying green lights but I am unable to connect. We disconnected the the router from the mains and re connected it but still no luck. I also tried connecting a phone but I'm unable to find the router. I checked the service status on the sky app and everything seems fine.
Message posted on 13 Sep 2025 01:54 PM
Re: The lights are on but no connectivity
As you have just the service status then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 13 Sep 2025 02:00 PM
Hi thanks,
I ran the test and everything seems 'green' however no luck with rectifying the issue unfortunately.
