Discussion topic: The device is not working.
Message posted on 24 May 2025 06:03 PM
The device is not working anymore. I need a new one.
Message posted on 24 May 2025 06:05 PM
Re: The device is not working.
@Tavixzx I'm afraid you're going to need to provide more info, what device are you referring to?
In what way isn't it working?
Message posted on 24 May 2025 06:07 PM
The internet device.
Message posted on 24 May 2025 06:13 PM
@Tavixzx You mean your broadband hub? In what way isn't it working?
To help you we really need to know what the actual issue is "Not Working" isn't telling the community anything useful.
Message posted on 24 May 2025 06:30 PM
The device is broken.The VOICE light stays on red. And I don't have internet.
Message posted on 24 May 2025 06:32 PM - last edited: 24 May 2025 06:34 PM
@Tavixzx Your latest thread has been removed as you already have this one, creating duplicate threads is unhelpful. In addition your hub is working perfectly fine, it may suggest a fault on the network.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 24 May 2025 06:34 PM
Water fell on it and it stopped working.
Message posted on 24 May 2025 06:36 PM
@Tavixzx You could have prvoided this info to start with, in this case you'll need to call Sky they may charge you for the damage.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
