Discussion topic: The WiFi when tested says theirs no issue but it is not working
Message posted on 24 Feb 2025 08:18 PM
Internet is not connected it has two green light but no light on internet and is not connected to any device in the household
Message posted on 24 Feb 2025 08:38 PM
Re: The WiFi when tested says theirs no issue but it is not working
@Michelle205
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
