Discussion topic: Terrible Wifi Speed
Message posted on 13 Dec 2025 12:56 AM
Re: Terrible Wifi Speed
@Mightyslug Use you best device the laptop, try a few test's various times but try to stick to the same test server ookla app on windows is fine you get to keep the history, then will give you a better idea, that will cover what your home connection is like, you cannot shoot the sky Max hub until you get all the fact's.... Fact 1 your network could be real busy just now everyone watching and streaming movies etc so that is why you have to spot check same times, ie 8am, 11am 2pm, 6pm 8pm 10pm etc you need a few day's to see how and what it is like!
Message posted on 13 Dec 2025 01:02 AM
Appreciate the help.
The house is currently empty apart from myself running the tests so there isn't any traffic at the moment.
I will run a few more times over the weekend and see if it suddenly cleans up its own mess.
Message posted on 13 Dec 2025 08:42 AM
@Mightyslug It's just not your home, this is what is involved with th Fibre optic connection with you so from OR Below.
1. FTTP is a contended service, up to 32 users can be sharing the 2.5Gb backhaul, so you can never expect the full speed all the time, you may get 900mb when there are fewer people using it. I expect that you are sharing the backhaul with many users. If everyone was using it fully, you may only get 78mbs. Its called statistical multiplexing, which relies on the fact that all users are not utilising their connection fully, all of the time.
BT quote up to 900mb, so you are likely to get much less than that during peak times.
Speed tests pass very little data, so normally give a much higher speed.
2. The max OR connect to a splitter is 30 ( 32 is the splitter maximum but policy is 30 ) not every CBT port provided is likely to have a customer using it , so unless on a ‘new site’ that has no alternatives to OR FTTP the actual number on a splitter is likely to be way less , OR currently have about a 30% take up, so maybe 10 users per splitter , plus the majority don’t take 900Mb but slower profiles , and the chances of those ‘on line ‘ at any one time all and doing something intensive, rather than browsing / Netflix that may be consuming less than 30-100Mb , is slim , that’s why there is a 700Mb minimum speed guarantee on 900Mb …..the 2.4Gb will be plenty ,you would have to be incredibly unlucky to have any consistent congestion.
If you suspect PON congestion, try at a time when there won’t be much activity, late evening or early morning .
Although you have tried somethings to ‘ isolate’ the problem , the most obvious thing to do ( that you haven’t apparently tried ) is use the BT router , without doing that , you haven’t really proved anything , your third party router may great , but even great routers can be mis configured or faulty
