Discussion topic: Taking over a firbe box in house instead of the cooper wire
Message posted on 26 Jun 2024 11:09 AM
Hi i got superfast broadband at 1.8mb
and its too slow sky broadband is coming throgh copper cable
i do have two firbe boxs coming into the property one is being used by aquiss as i need it for word at 160mb
i would like sky to use the other box but i tried two year ago for them to use other box but sky said it dosnot show on there System
both boxs was installed by openreach
Message posted on 26 Jun 2024 11:13 AM
Re: Taking over a firbe box in house instead of the cooper wire
Could you enter your full address below and post the table and notes after removing your address from the image
Message posted on 26 Jun 2024 11:41 AM
Message posted on 26 Jun 2024 11:58 AM
The 330 Mbps wbc fttp suggests that maybe the initial connection was installed by openreach as part of a rural community due to vdsl speeds not capable of delivering more than 10Mbps superfast or as part of a government voucher scheme in both cases sky is always a authorised reseller hence possibly why they installed it for aquiss.
Message posted on 26 Jun 2024 12:05 PM
So dos that mean they can do it and it show on there system
Message posted on 26 Jun 2024 12:10 PM - last edited: 26 Jun 2024 12:13 PM
It could well be the reason Sky cannot see FTTP availability on their sales system: a typical listing would show 1000Mbs inbound and 220Mbs outbound.
Message posted on 26 Jun 2024 12:16 PM
What area of the uk are you in? Is it rural?
Were the openreach boxes there when you moved in . How did you end up selecting aquiss as a provider.? You may have to go back to them to either upgrade your active box to 330Mbps or to see if they can give you a new line on the second inactive ont
Message posted on 26 Jun 2024 12:18 PM - last edited: 26 Jun 2024 12:23 PM
330/50 was also the fastest offering if 'business broadband' over FTTP was ordered a few years ago: it's what BT Business resold under their 'Infinity' branding, so Aquiss may have done the same.
