3
This discussion topic has been answered Discussion topic: Tablet and laptop not connecting to WiFi only
This message was authored by: Supermechanich
We have a strong WiFi signal but my Amazon Fire Tablet and Asus laptop will not connect, all other devices connect immediately without issue. Could it be that older devices cannot differentiate between the 2.4GHz and 5GHz signals? If so what's the cure?
This message was authored by: CoffeeDrinker Answer
Re: Tablet and laptop not connecting to WiFi only
@Supermechanich wrote:
White one
It could be that your Fire tablet might not support the WPA3 WiFi security standard. To check, go into the MySky app on your phone > Broadband > WiFi settings > Advanced settings > WiFi security level > change from"WPA3-T (default)" to "WPA2".
try to join your Fire tablet to WiFi again. If it works, leave the security level at WOA2. If it doesn't, return the setting to WPA3.
Sky Glass & Stream Puck customer w/Sky Entertainments & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
@Supermechanich  What colour of router do you have from Sky to see if there is an abiliity to split the Wi-Fi frequencies.
Avatar for Supermechanich
White one
White one
