Discussion topic: TV signal drops out and then tells me my WiFi password is incorrect
Message posted on 07 Oct 2025 10:02 PM
My TV has lost connection multiple times tonight and then when I tried to reconnect its telling me my password is incorrect!
I have reset and followed all the help
Message posted on 07 Oct 2025 10:16 PM
Re: TV signal drops out and then tells me my WiFi password is incorrect
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
Message posted on 08 Oct 2025 08:16 AM
My WiFi password was entered correctly previously and all other devices are fine just TV. I can see others have had issues will see if it is sorted today otherwise ring sky thanks
