Discussion topic: TV, Broadband and Internet Outages
This message was authored by: Diana_Likes_Win
In Newcastle area. For several weeks now I am getting, blackouts to tv, fibre signal, Internet. With no connection reported. This has increased this week with frequent outages, very unreliable now over the weekend. When it is up signal is very slow. Reported on down detector, checked sky outage and often the check itself is down during the outage. Clearly something external with the service is broken.
Re: TV, Broadband and Internet Outages
@Diana_Likes_Win
