26 Jan 2025 04:22 AM
I have FTTC and am on sky 500 package and looking to replace the sky hub and connecting the AXE75 router directly to the openreach modem.
Anyone know the settings?
26 Jan 2025 07:29 AM - last edited: 26 Jan 2025 07:30 AM
Posted by a Superuser, not a Sky employee. Find out more@Kully1972 not an ideal choice of router as TP-Link do not support Sky's normal authentication system DHCPv4 Option61 so you will need to try DHCPv6 PD which most but not all lines will support.
Note you do not have FTTC which is partial fibre if you have an ONT you have full fibre FTTP.
26 Jan 2025 10:11 AM
Many thanks!
So I have FTTP!
I`ll try th TP link settings with a connection from the modem to the WLAN port and see how it goes
Should this fail I`m likely to get an Asus router with merlin software which dhould do the trick!
06 Feb 2025 09:35 AM
May I ask what luck you had on this TP-Link router please.
06 Feb 2025 10:00 AM
I'm being connected to sky fibre next week on Friday.
I'll let you know how I get on!
The router has all the settings done so hoping I'm ok.
