Discussion topic: TP-Link Deco S4 AC1200
This message was authored by sanyry This message was authored by: sanyry
Is TP-Link Deco S4 AC1200 working with sky broadband? I want to boost my signal upstairs. Thanks
Re: TP-Link Deco S4 AC1200
@sanyry you can use any Deco system set to operate in Access Point mode with your Sky hub acting as the router with its Wifi disabled. As far as I am aware you cannot connect a Deco directly to any Sky broadband service in the UK (Ireland is different) as the units do not support Skys DHCPv4 Option 61 requirement.
sanyry
Thank you. Do you have different suggestion as well to extend my signal upstairs? Or Deco will do it well?
