16
Discussion topic: TP Link AX3000 with Sky FTTP
This message was authored by Tandridge This message was authored by: Tandridge
I am trying to get a new TP Link AX3000 router to work!I have tried via the TP Link App and I can't get away from it asking for the PPOE username and password. Sky won't help at all and say they will only support their router. I have a BT Whole Home Mesh system at the moment, with 5 discs in total as we have a large Victorian house over three floors, however still have problems seem to lead back to the Sky hub, which we had before we had the FTTP and ONT modem installed. I searched long and hard but cannot find an amswer that gives the correct login and password that TP Link is asking for. I have tried the abcdefg1234@ etc and they don't work. Any simple solutions? Before anyone asks, I have turned off the wi-fi on the sky hub, so just use the MESH for access. Thanks!
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: TP Link AX3000 with Sky FTTP
@Tandridge
The process for authenticating a tp link ax router in the uk is called dhcpv6 prefix delegation
See below
Tp link AX is on latest firmware
IPV6 on (advanced menu option)
Dynamic IP (SLAAC/DHCPv6)
advanced settings: DHCPv6
prefix delegation enabled
DNS address: get dynamically from ISP
IPv6 LAN
SLAAC + stateless DHCP
MAC Clone: Use Default Mac address
@Tandridge
See below
IPv6 LAN
This message was authored by Shaydon193 This message was authored by: Shaydon193
@cookiemonsteruk I tried following your settings to no avail 😞
network works fine as soon as i revert to the sky hub, going through the tp link settings doesn't seem to work at all - also left it about 20/30 mins to try and connect after using your settings which didn't work.
Also have Sky FTTP 500
This message was authored by Charliecossie This message was authored by: Charliecossie
I have an AX5400 and I could not get it to work. Then I followed the instructions above and connected instantly.
How long did it take to connect? I left mine for over 20 mins and the orange internet light was still showing and wasn't able to use the internet.
This message was authored by CooperBDO7 This message was authored by: CooperBDO7
Hi I have the exact same router and problem, followed the suggest advice to the letter and even tried a few options here and there and still nothing.
Tandridge
I have given up. I tried to follow various instructions and suggestions, none of which worked. Sky clearly won't play ball, which is petty. I have moved my sky router to another area that I can link the FTTP to, and then set up my mesh network from scratch again, and it's better, I still have only 60mps in a few areas of our house (500mps FTTP) but get 150mps+ in the important places so I can now live with it.
This message was authored by Sheikhy This message was authored by: Sheikhy
@cookiemonsteruk
Many thanks for this info. I had been scouring forums to set up a TP-Link VR2800 to the Sky fibre to no avail until I saw this thread.
router was connected to the openreach ONT via Ethernet and in wireless mode. Within a couple of minutes of adding the correct settings you mentioned, the router connected to the internet and started working correctly. WiFi is much stronger around my house now with fewer dead spots compared to the standard sky router.
Thanks again!
This message was authored by Raths This message was authored by: Raths
So i have the new AXE75 aka AXE5400 router & was wondering how to set it up? Do i need to do PPPOE? etc if so what settings
This message was authored by testicles This message was authored by: testicles
Thanks!
This also worked on a TP Link AX3000!
This message was authored by Bynar This message was authored by: Bynar
Can confirm these instructions work on an AX72, but you MUST update the firmware on the router first. It will not work until you do.
bit late
This message was authored by Rdbarry This message was authored by: Rdbarry
After much fiddling, googling  and almost giving in to having to use sky router, these settings worked like a charm. I could kiss you. Thank you
This message was authored by Stevejp This message was authored by: Stevejp
using either of the tp link routers mentioned here, is it possible to still use the sky router for the voip phone ?  could the sky just be linked via ethernet to get voip working ?  long shot I know
Just upgraded to the tp link ax55 and using on fttp. Following above instructions all now working amazing:-)
