Discussion topic: Switching from Superfast to Ultrafast plus
This message was authored by maiciej This message was authored by: maiciej
Hello I was wondering if switching from superfast to ultrafst plus provides a new instalation of wires. As I know ultrafst wasn't in my area previously and my internet was going through copper wires. Is instalation of this new wires that are going through those poles free or do I need to pay extra for an instalation?
Re: Switching from Superfast to Ultrafast plus
@maiciej
It would require a new installation of fibre optic cable but that should be done via the existing route the copper line take. There may be around £19 setup fee for the new fibre optic modem
If you wish enter your full address below and post the table and notes below after removing your address from the image
maiciej
maiciej
here is a screenshot with details below
@maiciej
The notes below would be handy as they state any anticipated issues .
At the minute 1 stage install and no issues should cost you nothing apart from the £19 for the modem
maiciej
@maiciej
Plus single dwelling no anticipated issues should as above should be free
@maiciej
And o/h (overhead) means it will come in from a telegraph pole alongside the existing line
maiciej
so instalation would be free and I would only have to pay extra for a new router right?
@maiciej
Depending on what hub you have at the moment you would also get the sr203 free of charge
The new ont takes over the role of the integrated vdsl modem inside the hub
The ont fibre modem (below) maybe the only thing you pay for
@cookiemonsteruk wrote:
@maiciej
That should be included in the Openreach FTTP installation budget allowance: I'm not aware they charge.
@maiciej
There used to be a charge for a subsidised ont at C£19.95
