12
This discussion topic has been answered Discussion topic: Switching from BT to sky broadband today,
This message was authored by: mrjohnny9
Switching from BT to sky broadband today, have read that it is easier to change/replace sky SSID with existing BT SSID rather than change numerous device id's? Is this possible/easy to do and how you doing it please, have read a few write ups but sure if it's doable
Re: Switching from BT to sky broadband today,
@mrjohnny9 in the My Sky app click on Broadband, scroll down yo Product Options, click on Sky Max hub on the page that appearsclick on the pencil icon which should allow you to edit both the SSID and the WiFi password to match your old router. Once the change is saved and hub has restarted your devices should connect without further action although a few may require a re-start.
@mrjohnny9  Did Sky give you a black or white router for your service?
Avatar for mrjohnny9
Unsure ATM as not home until Saturday
@mrjohnny9  With the white router that would be done via the Sky app to make changes, but with the black router it is done via router management. Once you know what router you have come back let us know.
@mrjohnny9 if you get a white hub which is likely if buying full fibre you can indeed edit the SSID and WiFi password using the My Sky app navigate to the Sky Max settings area and use the pencil icon to open the edit field. If you have a black hub you can edit the WiFi details in the hub's web interface by typing 192.168.0.1 and clicking on the WiFi tab and logging in with the username admin and the WiFi password on the hubs label.
It is a sensible step to save efort my own WiFi log in is from a router which has been  history for several years.
It will be the white one as we have fibre to the house
@Chrisee hi I now have my sky max hub working today, so using the sky app am in the settings area, is there a SBS for changing the SSID using my BT id to save changing all devices please?
@Chrisee have tried that but hub not showing in broadband section of the app? Am I missing something here?
@Chrisee @Have tried logging out and back in again but still not showing
@Chrisee @Deleted the app, reinstalled it again but still not seeing an option to change hub settings
Sorry @mrjohnny9 you will need to get Sky to fix it for you.
@Chrisee hi, just to update you, all working now thx, SSID changed+ password, existing devices automatically reconnected, seems there is a few hours delay for the hub settings to appear in the sky app, thanks for your input
