17 May 2024 07:35 PM
Switched from EE today to Sky. Hub installed and we have WIFI. However we have now have no landline. When someone calls our home number they say it rings but it doesn't ring at our property. There is no dial tone on the landline handset. All mobile and broadband equipment works perfectly but we've lost the landline. Can you advise
17 May 2024 08:29 PM
What broadband connection do you have fttc or fttp ?
Have you plugged your phone into the back of the sky router?
17 May 2024 10:02 PM
Got no idea what those letters mean sorry. We have a two port master phone socket on the wall. Left hand (small plug) goes to the broadband hub. The right hand (larger plug) currently goes to the base unit of the landline phone. It has a small plug on the end that fits in the base unit. This small plug doesn't fit in the hub so I cannot plug the phone wire straight into the back of the hub from the wall. If I did how would the hub communicate with my base unit without a cable?
17 May 2024 10:55 PM
What hub did you receive from sky ? The one that lies flat or the upright model. As of september sky has issued a broadband hub with a bt phone socket in preparation for the rescheduled pstn telephone switch off in january 2027
18 May 2024 07:48 AM
Posted by a Superuser, not a Sky employee. Find out more@Chadwick1968 look at your Sky hub if it has 4 LEDs and the one on the right is green then you plug your phone into the phone socket on the back of the hub to use the landline.
As pointed out the older type of phone service where the phone plugged into the phone socket in the wall is being gradually switched off most new connections Sky offer provide the voice service via the hub and tge phone points around your home will no longer work.
