4
This discussion topic has been answered Discussion topic: Switched provider and Sky advise broadband active but still have BT broadband connectivity.
This message was authored by: AnthonyFrankel
I have changed provider from BT.  Their router connected via the OTN.  Sky Activation date is today, hub received and Sky confirmed activation achieved earlier today.
BT connection still up ad operating normally so do I just disconnect their router from the OTN and substitute the Sky or must I wait for the BT connection to go down?  Haven't had an update from Openreach since yesterday since theuy confirmed they would activate today.  Do I need to weait to here from them again?
Avatar for AnthonyFrankel
This message was authored by: AnthonyFrankel Answer
Re: Switched provider and Sky advise broadband active but still have BT broadband connectivity.
Can be closed - confirmed that current provider circuit can remain up whilst I switch router - now successfully implemented.
@AnthonyFrankel The way that it works is if sky has informed you that they have you now they grab hold off the connection but the BT hub still keeps you working until you put the sky one on the connection.
Once the sky hub is connected and it establishes itself on the Network, does it's FW updates and reboots etc and then is good to go from that point onward. Sky do have up until midnight off the activation day for them to make it all work as needed! OR tell sky first they are done, sky tell you and if BT/EE are involved you should also have an e-mail possible text that they have let you go!
Many thanks for the prompt response.  I managed to speak to Sky before I read your post but most grateful for your prompt and helpful reply.
@AnthonyFrankel No problems, welcome to sky and the Forum,,,, and the sky Help also is going to be your best friend.👍
