Discussion topic: Switch from BT To Sky
This message was authored by CWinter This message was authored by: CWinter
Hi, I live in a large "U" shaped bungalow and have Wi-Fi issues because of the size and shape of the property and we currently have BT Broadband which is due for contract renewal. We also have Sky Q plus 3 Sky Mini Boxes, the furthest mini box is network cabled to the main Q box and the others connect via Wi-Fi. The BT Router provides the only Wi-fi signal to the Main Q box and all other devices except the Mini Boxes. The Wi-Fi signal is quite poor as is the local speed which is circa 30Mb, so no local superfibre here yet in our village. So my question is this - if I switch to Sky Broadband will the Sky Mini Boxes then act as Wi-fi extenders and create a better Wi-Fi mesh than i have at present?
Many thanks
Chris
Re: Switch from BT To Sky
@CWinter
Yes they should create a better WiFi environment but it cant be guaranteed as all environments are different.
I am NOT a Sky Employee
This message was authored by JPR007 This message was authored by: JPR007
@CWinter Just bare in mind that Sky still provide the service down the same line, so speeds will still be broadly similar to the property, if it's not a new new service and aren't yet lucky enough to get full fibre.
Sky will quote you a bare minumum speed they think can be provided if you take out a contract in your joining email.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
