5
This discussion topic has been answered Discussion topic: Swish fibre
This message was authored by: private.lawyer
Swish fibre
Hi I got 3 months of swish fibre broadband for free, how can i get my sky broadband back as I'm still paying for it.
Re: Swish fibre
@private.lawyer
Swish would have installed their own fibre-optic cable and ONT, but they should have left the Openreach optical infrastructure intact.  If that's been damaged and you still have an active Sky FTTP subscription then you'd need to log a fault through Sky for Openreach investigation: for that you'd need the Sky Hub plugged in to the Openreach ONT.
Re: Swish fibre
@private.lawyer
If you didn't cancel Sky Broadband then is may still be active: Swish is an altnet using its own optical private infrastructure.
Note however they the newly-introduced extended one-touch-switch system does complicate things: it now means that by default ordering service from an altnet will cause broadband from an Openreach ISP to be cancelled.
Avatar for private.lawyer
Re: Swish fibre
Sorry I forgot to mention they changed the wire outside
Re: Swish fibre
Re: Swish fibre
@private.lawyer
Re: Swish fibre
Thank you @TimmyBGood will get on it now.
