Discussion topic: Surrey outage evening of 04/09/25
Post created for collating posts re outage in Surrey.
This message was authored by: Clemy8
No internet
No internet. On hold to sky. Just flashing  green light on the sky box.
app keeps saying it's fine and we have connection but we don't.
can't get onto anything!
anyone else ?
Avatar for Daniel0210
Level 16 icon
Re: No internet
@Clemy8
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
This message was authored by: Alex1568896
Re: No internet
I've got nothing either... looks like it's down for a lot of people
This message was authored by: Surrey+Gooner
Re: No internet
Mine is also not working and long hold to sky contact
I guess everyone is having the same problem
Maybe they've been cyber attacked 😳
This message was authored by: Db0909
Re: No internet
Same here. Slow pulsing green light on router since around 6.30pm. Service checker reporting no outage.
Level 16 icon
Re: No internet
@Surrey+Gooner
No. There're millions of Sky broadband customers and at any given time they'll be a few who have an issue. If it was an issue affecting everyone then
a) I wouldn't be replying to you and
b) the forum boards would be crashing
Re: No internet
Spoke to sky. Apparently an open reach outage all over area. I'm Surrey.
very annoying. They said as it's late it may not get fixed tonight. Hopefully tomorrow.
Re: No internet
Clemy8
thanks for the update as also in Surrey and no internet but couldn't get through to Sky 35 minute wait on the phone
This message was authored by: AG631
No broadband
We have done all the tests and you say it's fine but it is not working!
This message was authored by: EH31
Re: No internet
We are in Surrey and have no internet too
Level 16 icon
Re: No broadband
@AG631
There is currently an issue in the Surrey area if that's where you are.
This message was authored by: Brad123456789
Re: No broadband
Me too.
This message was authored by: DaveB22
Re: No broadband
And me as well in Surrey. Internet went down around 6:30pm and Sky tests keep showing everything is fine.
This message was authored by: Cambo2
Re: Surrey outage evening of 04/09/25
Wifi is also down for me in Surrey, when I check on the sky app for the status it is saying it's down and can take a couple days to fix
